Help with coax cable
Im renting a second hand place and can't get the coax tv cable working. I've got tv included and the landlord said to just plug it into the wall... I've plugged the wire into my tv and nothing happens.
Anyone with comhem know how to get it working? Photos for reference:
You need to do a channel scan for digital tv (DTV) / Cable, all necessary settings are listed here:
https://comhem-assets.azureedge.net/zkxtxpb8wn5p/2cZ0S2sN03fx...
Use Google Translate or your translation service of choice to translate the document.
If like you seem to say, haven't really tried anything you should search for channels in the DVB-C-mode of your tv (assuming it has one, which they normally do if they're not quite old). If that doesn't work you could try the analogue mode, but that has usually been switched off.
Skrivet av diizzy:
Thanks, I appreciate it - but I can't figure out how to do a channel scan. It's not showing up that the cable is plugged in when I have the tv on. No new source for the coax or live tv or etc.
Skrivet av diizzy:
You don't always need to input the number, but if it doesn't work without it, one can try that. I haven't had to input it with ComHem (which merged with Tele2), but I did ~15 years ago with Tele2Vision (which was sold to Bredbandsbolaget/Telenor...).
Skrivet av LeatherPatch:
So what does the manual for your TV say about ”auto tuning”, ”cable search”, ”channel list” etc?
Skrivet av KAD:
There is nothing in the manual about it.
https://www.samsung.com/se/support/model/UE55NU8055TXXC/
Contact samsung support.
Either the missed to add that chapter in their manual or it doesnt have any coax module just a port for it cause the motherboard/chassi is shared with some model that has a tv module.
ASUS B550-f-Gaming, R9 5800X3D, HyperX 3200Mhz cl16 128Gb ram, rtx 3070ti.
[Diskussion] De bästa gratisprogrammen för Windows
CPU: Ryzen 9 3900x Noctua NH-D14 MOBO: TUF Gaming X570-PLUS GPU: GTX 980 RAM: 32 GB 3200 MHz Chassi: R4 PSU: Corsair AX860 Hörlurar: SteelSeries 840 Mus: Logitech G502 Lightspeed V.v. nämn eller citera mig för att få svar.
It's not a source. It is just an "antenna" cable for the internal tuner.
DAN Cases A4-SFX | AMD Ryzen 7 9800X3D | Thermalright AXP90-X47 Full Copper |
INNO3D GeForce RTX 4070 Ti SUPER 16GB Twin X2 | Kingston 32GB (2x16GB) DDR5 6000MHz CL30 | ASUS ROG Strix B650E-I Gaming WIFI | Samsung 960 EVO 1TB | Corsair SF-600
Have you connected the right kind of coax? you need a 75 ohm one made for television signals, the one you have connected looks like an audio coax.
The cable should look something like this https://www.jula.se/catalog/hem-och-hushall/hemelektronik/tv-...
And it should be placed in the right most connector in the wall socket.
Skrivet av Ldarax:
Yeah exactly like this, it's a more expensive fancy one with gold plating for less signal loss.
Bu it is not made for television signals, the outer sheilding on the antenna cabel should be on the outside of the connetctor and the connection you put it in on the wall socket is an input.
Skrivet av Ldarax:
It should be, it's this exact model. https://amzn.eu/d/8sATOr4
Ok, then i not sure what could be wrong.
Skrivet av Ldarax:
The right most is for a male plug, the middle is female...but the plug I have is female and male, male plugs into the tv.
Explanation with picture of an older type of socket.
(You just plug the cable in the other way round depending on if it's a radio or tv, assuming there's still any radio signal in the cable network, which there might not be.)
This worked, thanks!
Now the only issue is I have about 10 channels, most are locked. Is that normal for having the basic offer at comhem?
Probbably.
I guess the only offer like svt1 + 2 and tv4 as free content the rest is probbably locked behind subscription and monthly payment.
